Gen 2 - Aftermarket Audio speakers
SimonB
Site Admin
Country: United Kingdom
Vehicle: 2017 Nissan X-Trail
Thu Sep 10, 2009 2:24 pm
I'm looking at replacing my Gen LWB front and rear speakers. Does anyone know what size the fronts are? What could be recommended as replacements, to run with a JVC CD/MP3 Head Unit
The titchy rears will be replaced by (most likely) 6x9's which will then be attached to my packing system
jbeez
Vehicle: 2005 3.8 GLS
Re: Gen 2 - Aftermarket Audio speakers
Fri Oct 09, 2009 3:43 pm
I removed the little 5watt speakers from the front and wnet to the local radio shop. Bough the closet no-name brand ones I could get and hacked off the one eyelet as the original only has three and not four as in a normal speaker. I still have the old ones if you need a template. Paid under R200 for a pair of 120W speakers and they work well.
Replaced the rear units with 6X9's but the sound is still bad. Currently running a Pioneer 50W/channel head. Using the same unit in Swambos platkar with origianl speakers as fitted by Honda and the sound is amazing.
Johann Bredell
jbeez
Tue Feb 02, 2010 3:26 pm
I went to the local audio shop and asked them to "fix" my sound. The disconnected all the installed speakers and fitted a set of Kenwood 6X9 in the bottom of the rear doors and two other Kenwoods in the front doors. Much better setup.
Johann Bredell
ma
magneto
Tue Feb 02, 2010 8:30 pm
I am also looking at changing my speakers, currently all standard.
What was the size of the front speakers you bought?
I am a Kenwood fan myself, so maybe they would be the ones.
Currently my Pajero is in for some work, so I can't get in there to take the others out. Will do as soon as the car is back.
SimonB
Site Admin
Wed May 26, 2010 11:14 am
jbeez wrote:I removed the little 5watt speakers from the front and wnet to the local radio shop. Bough the closet no-name brand ones I could get and hacked off the one eyelet as the original only has three and not four as in a normal speaker. I still have the old ones if you need a template. Paid under R200 for a pair of 120W speakers and they work well.
Johann.
What size were the fronts? Can you perhaps measure the old ones or somehow get a to scale scan of the template.
I now have the 6x9's which I will install in their own enclosures and fix to the packing system (still waiting for the ipod interface :? )
