I have received my EGT gauge in the post.
However. The gauge's k-type coupler grounds on the exhaust and doesn't give a readout.
If I use a separate 12v source passed to the gauge it works beautifully.
Is there a way I can pass independent 12v to the gauge to make it work?
EGT wiring help needed
- 4ePikanini
- Affiliate Member
- Contact:
- Country: South Africa
- 4ePajero
- Vehicle: 1989 Pajero LWB
Post
Re: EGT wiring help needed
Did the supplier give a wiring diagram?
Post that here, so that we can fully understand your problem.
- 4ePikanini
- Affiliate Member
- Contact:
Post
no wiring diagram attached.
If I have the EGT probe away from the vehicle it works fine but as soon as the probe is grounded (same ground as digital meter) the gauge reads zero.
They sent me the wrong k type probe - it doesn't have the threaded part over it that is insulated from the actual probe.
ie. The probe must not share a common ground with the gauge. I either need to unground the probe
or get another probe
or get an independant 12v to the gauge that doesn't share a common ground between the probe and gauge.
- 4ePajero
Post
If they sent the wrong probe, surely they have to replace it?
Who is the supplier?
- 4ePikanini
- Affiliate Member
- Contact:
Post
Ebay. I have sent a message but no response yet.
It wasn't very expensive so maybe I should cut my losses and get another from a different ebay supplier
- 4ePajero
Post
Get a probe from MGL Avionics.
They are not expensive and has a good rep. I paid R250-00 for mine (but that was 7 yrs ago!)
