I did the 4X4 trail at protea eco this weekend. It was so much fun and I was wondering how that track measures up. I thought it was quite rough but I don't have much to compare it with. How does it measure up to some other tracks?
The drive up the river and the final river crossing was also quite deep, should I check anything after going through that?
TN
PS thanks to Jannie and Mitsu for a fun day
Protea eco adventures 4X4 trail dificulty
- CATS
- Contact:
Post
Re: Protea eco adventures 4X4 trail dificulty
Always good to check diff oils after water crossings. I would rate Protea as about 2-3. In comparison I would say Groenkloof is about 2, de Wildt is 2-3 and Hennops is 2-3. Berakah about 3. At any one of these places one can do damage to your vehicle in certain instances if you dont follow basic principals. But then again you can also damage your car when parking in your own garage:-) . Most of these routes have easy parts most of the time with a few challenging obstacles here and there that warrant the highest rating. One could however probably do just the easier parts and skip the mayor ones which would reduce the level.
Above is my own personal opinion from visiting these places at various times over the last few years. Different weather on the day can change any route drastically. Also the routes might have changed since I have done them. Lately I am not so big on trails but rather touring.
th
Post
Thanks CATS
Now I can gage myself a little if an oportunity comes up. I also want to use it mainly for touring, but needed to get some expeience in what the veicle can do. As far as this trail goes, it did it quite easilly with a novice driver behind the wheel
I'm beginning to see what you guys are talking about!
