Need help please!Engine light iluminates on hard excelleration on long road,goes to limp mode.Suspects dump valve is sticky.can one reach without removing turbo?3,2 GLX,130 000 KM
Ollie
Cleaning sticking dump valve
- 4ePikanini
- Affiliate Member
- Contact:
- Country: South Africa
Post
Re: Cleaning sticking dump valve
Spray some penetrating fluid by the back of the turbo on the wastegate arm. Let it sit for awhile.
Then get a hand pressure pump and connect it to the pipe that goes to the wastegate and slowly increase up to max 2 bar and see if it loosens up and moves.
If not you will have to remove the turbo.
Am i correct in assuming your egr hasn't been blocked off?
Sent via iPad & Forum Runner
- 4ePikanini
- Affiliate Member
- Contact:
Post
You might want to remove airbox and turbo intake pipe for access behind the pump.
Ol
Post
Thanks,wanted to know if i have to remove air box.EGR not blocked off.
Leaving work now,will log on at home.
Ol
Post
I removed the filter box,turbo pipe,but still cant see the dump valve meganism?Where else?Thanks
- Bigwill
- Vehicle: 2004 Pajero 3.2 DID SWB
Post
If I am not mistaken our diesel Pajeros do not have a dump valve. It does however have a waste gate. My understanding is the wastegate maintains and controls the maximum presure at an ongoing basis. A dump valve normally on a petrol engine with a big turbo avoids damage to a turbo when the driver shuts off the throttle suddenly while the turbo running at ultra high revs and pressure at that stage has a "pressure crash" as the pressure has nowhere to go. The dump valve is there to dump all this pressure immediately, else damage to the blades may occur.
Willie from Jo'burg
- 4ePikanini
- Affiliate Member
- Contact:
Post
correct. When a certain boost is acquired determined by the wastegate diaphragm spring the diaphragm spring pressure is overcome that moves the wastegate actuator arm that opens the wastegate on the exhaust side. This bypasses exhaust gasses away from the exhaust turbine on the turbo and because of that the exhaust turbine spins slower and the boost is limited.Bigwill wrote:If I am not mistaken our diesel Pajeros do not have a dump valve. It does however have a waste gate. My understanding is the wastegate maintains and controls the maximum presure at an ongoing basis. A dump valve normally on a petrol engine with a big turbo avoids damage to a turbo when the driver shuts off the throttle suddenly while the turbo running at ultra high revs and pressure at that stage has a "pressure crash" as the pressure has nowhere to go. The dump valve is there to dump all this pressure immediately, else damage to the blades may occur.
Ol
Post
Thanks for the feed back.What can my problem be?Occasionaly the engine management light comes on on hard excelleration.Had similar problem with Td5,which was the dump valve or waste gate.Thought both were the same.Paarden island wants R550 to do dianostic,5 Hrs labour to remove turbo to clean.Thought i could lubricate myself.Will proberly have to that way.
- 4ePikanini
- Affiliate Member
- Contact:
Post
try to get the error code read first or use my DIY
http://direct.pajeroclub.co.za/forum/vi ... =52&t=3193
- Nismo
- Vehicle: 2005 Pajero 3.2 X-Treme
Post
Sorry if off topic, what can it be if you connect a boost gauge and see the boost go up "rukkerig" its not smooth on the boost gauge?
2009 Pajero 3.2 LWB GLX
OME Suspension
ARB Bumper
FR Roof Rack
OME Suspension
ARB Bumper
FR Roof Rack
