I will be pulling a friends bushlapa miskruier through the Mabuasehube area in the KTP - so expecting lekker sand and a few small to medium sized dunes. Expected weight of the trailer is around 1.1 tons
![](https://emoji.tapatalk-cdn.com/emoji37.png)
In terms of general tips I've seen folks recommend towing in 4H on the tar. Any other tar tips other than taking it easy on the pedal? (Will be watching my EGTs with interest!)
Offroad towing tips for the sand? I assume the usual low tyre pressure and lots of momentum will the order or the day... I've been told to also disconnect the inertial brake on the trailer when doing the dunes as it stops some of the back and forth kicking when you get those up-and-down humps or at the bottom of dips between dunes.
Do you agree? Any other tips?
